Post by usmcdoc on Apr 21, 2012 8:53:25 GMT -5
Anybody know where to find a Minarelli up gear guide? A tutorial on how to do the swap.... :stumped:
Post by reveeen on Apr 21, 2012 12:32:35 GMT -5
It's not a big deal... just put it back as you found it (including washers/shims), you will need a press of some kind.
Lacking a bench press..... I used a ball joint press.
Usually the replacement gears are straight cut, so they are a bit nosier than stock.
Post by aeroxbud on Apr 21, 2012 15:03:06 GMT -5
I like the stage 6 ones if you can get them. They are ready pressed so its just a matter of swapping them over.
Post by 90GTVert on Apr 21, 2012 18:25:12 GMT -5
