Post by usmcdoc on Apr 22, 2012 18:08:16 GMT -5
AGM Batteries suck!Got 2 brand new ones....they are supposed to ready to go from the factory....neither worked...one showed 9 volts...the other showed 6.8..... So I put them on the nice fancy new and expensive charger I got. Guess what?....you can't use a regular charger for them.... if the voltage is less than 11 volts their web site says.....you charger thinks it is shorted battery....or has a bad cell...and WILL NOT try to charge it...it just cuts out via the built in safety electronics. So now ya gotta run out...spend 70 bucks on an AGM charger for a battery that cost ya 25 dollars.....and they call them the latest in high tech for batteries?... I think they are garbage....
:swear:
Post by Deleted on Apr 22, 2012 18:17:00 GMT -5
Are they those Xtreme ones? I saw 2 bad ones in a row that were new also.
Post by Deleted on Apr 22, 2012 18:25:46 GMT -5
Post by usmcdoc on Apr 22, 2012 19:50:48 GMT -5
No the brand is power max...they should be called...'powerless'....... :bfg:
Post by Deleted on Apr 22, 2012 19:51:55 GMT -5
No the brand is power max...they should be called...'powerless'....... :lol:
