Post by 90GTVert on Feb 15, 2010 5:57:32 GMT -5
Rear Turn Signal RelocationI'm not a fan of the stock rear mudgaurds on these scooters and to remove them you have to relocate the rear turn signals. I know someone was interested in this, so I took a few pics. It's really a simple mod. I just made an L bracket for each side to mount the lights. You just have to mock it up before cutting and drilling because it's a pretty tight fit. Here's the right side bracket, bolted through the frame. Here it is with the turn signal installed. (I removed the plastic spacer at the end of the signal.) Here are a couple of pics with both lights done. This is an old pic of my other scoot, but it shows what this setup looks like with fairings installed.
