jlb71
Post by jlb71 on Apr 26, 2012 20:08:52 GMT -5
So I bought a polini high speed variator it says in the instructions to get rid of the starter does anyone know why?
jlb71
Post by jlb71 on Apr 26, 2012 20:10:45 GMT -5
I have a 2005 cpi Oliver city 96cc
Post by 90GTVert on Apr 26, 2012 20:22:10 GMT -5
I've never used that vari but I'm guessing it has elongated guides/tracks for the ramp plate to travel farther on the back of it? If so, the variator is too thick to fit and work right with the starter clutch in place. The Malossi over range variator needs part of the case that the starter clutch rides on removed as well.
jlb71
Post by jlb71 on Apr 26, 2012 20:41:20 GMT -5
Wow! This variator should work pretty good besides not have electric start
Post by 90GTVert on Apr 26, 2012 20:45:43 GMT -5
I know really nothing about it, but I certainly enjoy the performance from my Malossi OR that has those long tracks. Just make sure you keep that kickstart setup tip-top, cause you have no backup.
jlb71
Post by jlb71 on Apr 26, 2012 21:03:28 GMT -5
Yay I know about not having a back up last year I built a qmb with a cheap kit off of eBay and I kept killing the kick starter gears and the electric start wouldn't work found out the cylinder and piston clearance was a little to tight took it to a friend he took 20thousands out of the cylinder problem solved
Post by jmkjr72 on Apr 26, 2012 21:24:16 GMT -5
it tells you to remove the starter stuff becuase its an oversized varatior basicly you installed 1/2 of an over range set up
jlb71
Post by jlb71 on Apr 26, 2012 21:32:04 GMT -5
Should I replace the drive face are will the stock work
Post by jmkjr72 on Apr 26, 2012 21:42:47 GMT -5
i wouldnt run an oversized varatior with out the mathcin drive face
if it wasnt oversized you would be fine but the gain from an oversized is to allow the belt to go higher and give you a diffrent gear ratio
jlb71
Post by jlb71 on Apr 26, 2012 21:57:47 GMT -5
Can you recommend a good drive face?
Post by peteyparado on Apr 27, 2012 4:37:33 GMT -5
i got the scooter ninja variator an its the same way i must remove the starter gear,or it grinds on the drive boss!!! its all about kick power.. worth the few mph...
Post by 2strokd on Apr 27, 2012 5:53:46 GMT -5
Can you post pics of the two next each other? OEM vs aftermarket..
jlb71
Post by jlb71 on Apr 27, 2012 8:26:04 GMT -5
As soon as I get the the motor back from the machine shop I will post a pic Thanks for all the responses
