Post by fickertravis on Apr 27, 2012 21:15:40 GMT -5
I've had some trouble getting my base gasket to seal properly. I'm guessing the mating surface isn't true. I've heard and used the black gasket maker before from local auto stores. Is there anything that will for sure seal it up tight though? Been browsing different types of gasket sealers on Ebay.
Post by racerbugg on Apr 27, 2012 21:24:23 GMT -5
Post by fickertravis on Apr 27, 2012 21:49:05 GMT -5
Thanks, that looks like good stuff. Might order some
Post by racerbugg on Apr 27, 2012 22:01:39 GMT -5
i get mine at Canadian Tire
Post by 90GTVert on Apr 27, 2012 22:39:17 GMT -5
Threebond 1194 is another that will seal it unless there's a real problem. Same thing I use to seal cases. The issue with it is that it's hard to remove.
Post by fickertravis on Apr 27, 2012 23:22:01 GMT -5
Yea,I was looking at the threebond 1194. Pretty good stuff then?
What about the 1211?
Post by 90GTVert on Apr 28, 2012 0:03:38 GMT -5
Dunno about the others. I tried 1194 and it hasn't failed me yet so I've stuck with it.
Post by reveeen on Apr 28, 2012 1:41:56 GMT -5
