Post by 90GTVert on Apr 30, 2012 11:10:48 GMT -5
I'm not familiar with the model, but the mixture and idle speed screws should be on the side of the carb. Mix is usually a small recessed screw and the idle speed is usually a larger screw.
Not quite understanding "it started a while then dies after a long kick start". Do you mean when you kick it, it tries to run or do you mean you start it up and it will run for a while but dies or what exactly?
