Post by maconboi on Apr 30, 2012 17:41:14 GMT -5
My headlight on my taotao ATM 50 dim down alot on idle when RPM increases it brightens back normal thought it might be the crappy stock Batt. i checked all the connections and grounds they look good any suggestions?
Post by Deleted on Apr 30, 2012 17:44:46 GMT -5
thats normal since the headlight runs directly off the stator.
Post by maconboi on Apr 30, 2012 17:53:24 GMT -5
oh so it's not like a car where the batt runs everything and the stator/alternator recharges the battery? might be better to rewire it to ignition switch with switchable wire to the battery?
Post by Deleted on Apr 30, 2012 17:56:33 GMT -5
It is wired the way it is because the battery is too small for anything more. if you do anything rewire the entire headlight system wiring with larger gauge wires.
I decided to just get used to it since i need to see more when im moving vs. when i am sitting.
Post by maconboi on Apr 30, 2012 19:32:00 GMT -5
True it's not that big a deal for now. Thanks for the input
Post by 90GTVert on May 1, 2012 5:59:54 GMT -5
You can up the idle speed if it really bugs you. Of course make sure you aren't speeding it up so much that the clutch is engaging and trying to drive when you don't want it to. I have seen a a friend's scooter come stock with the headlights wired to battery power. He liked that it didn't dim, but it wasn't long before he started having issues with a low/dead batteries. He went overkill and stuck a small car battery under the seat. He said it fixed the problem, also added a ton of weight and killed all of his storage though. lol Even with a car battery, if it's having trouble keeping up it should eventually drain it if you don't put it on a charger when it's parked.
Post by skuttadawg on May 1, 2012 23:11:12 GMT -5
Put in a LED tail light and the head light(s) will be brighter
Post by maconboi on May 3, 2012 15:30:13 GMT -5
wow a car batt under the seat lol that is overkill! i was thinking a garden tractor battery we carry them at my work and there less than MC batts under the seat i didn't think of that. but think i'll try skutta's idea first don't want batt drain issues.
