Post by bellard on May 1, 2012 7:25:40 GMT -5
Hello everyone this is my first post so hello. I just recently traded a cdi and bbk for this bike. Its not pretty at all the kick start is broken off. The throttle line is broke along with the headlight and Jerry rigged ignition. I'd like to replace all of this Jerry crap . I also want to remove the oil pump and just premix. I've already removed the oil tank along with the throttle cable. I'm going to buy new grips because there old and shot. My question is. As far as the ignition I'd like to replace it. I usually shop on scrappydogs. I hear these minarelli engines are pretty quick and so far working on this bike I'm having alot of fun. I will be taking lots of pictures today. Any advice or suggestions are more then welcomed. Thank you
Post by 2strokd on May 1, 2012 7:52:28 GMT -5
Welcome aboard! They are pretty quick. My son has one with the stock 49cc. It will wheelie with a little help all the way down the road. I have read quite a few stories of running without the airbox, or filter on 2T,s lately. Make sure that is hooked up and the exhaust is sealed well or it wont run right. I got an ignition off of scrappy for my Kymco. Cheap lockset but it works good for me still. Had to swap a couple wires around but it wasnt bad at all. Need anything else for that scoot? Me and others here have spares for it so dont be afraid to ask EnJoY the lil bugger!
Post by bellard on May 1, 2012 8:14:22 GMT -5
Thanks bud for the advice most of the fairrings and seat bucket are junk. I guess ill have to find somewhere to buy new ones or fabricate some at work (sheet metal man) my biggest challange for this bike is gonna be the wiring on the ignition. Person before me had it Jerry rigged all the wires in the ignition plug on the wiring harness is good except the red wire. There's four red,green,black and black white I do believe. Any advice on where to get a new ignition for this puppy would be the biggest help thanks again Sent from my Droid using ProBoards
Post by 90GTVert on May 1, 2012 10:11:03 GMT -5
Post by bellard on May 1, 2012 10:14:27 GMT -5
I'm not very good with checking wiring I do have a volt tester fluke. And a ground to light tester. In the wiring harness there's 4 wires green red black and black/white ill look at diagram to see if it helps thanks a bunch vert you've helped me alot in past on scootdawg
Post by bellard on May 1, 2012 10:59:22 GMT -5
I looked on scrappy dogs in the common section for my ignition will the hunter ignition or b series fit? They both have four wires
Post by 90GTVert on May 1, 2012 11:46:10 GMT -5
Post by bellard on May 1, 2012 14:09:50 GMT -5
T throttle cable #2 ( Polygon junction box) $19.95 USD 1 $19.95 USD hurricane/zip key switch kit $44.95 USD 1 $44.95 USD 4 amp battery $19.95 USD 1 $19.95 USD Clear hurricane/zip tail light $34.95 USD 1 $34.95 USD type 3 (hurricane/zip) throttle grip set $5.99 USD
Hope I ordered everything right lol
Post by Fox on May 1, 2012 15:49:04 GMT -5
I have a seat bucket and body plastics in red. No front fender or speedo cover. I can send pics but only if you are seriously interested cause I have to dig a little to get to them.
Post by 49ccsofdestruction on May 1, 2012 19:28:59 GMT -5
bellard, i luv my '06 ls 49!! it does 40 mph with my 200 pound ass on it. has'nt given me any trouble yet. good luck.
Post by bellard on May 1, 2012 20:02:47 GMT -5
I mixed 2 gallons of premium with 8 oz's of 2 stroke. For some reason it wont start it wont start via the starter I checked the power in the ignition battery solenoid and any connection to the ignition it should crank but its not hmmm
Post by bellard on May 1, 2012 20:03:59 GMT -5
Picture of it bare Sent from my Droid using ProBoards
Post by bellard on May 1, 2012 20:04:34 GMT -5
Post by bellard on May 1, 2012 20:05:49 GMT -5
A snick in the harness luckily didn't scar a wire Sent from my Droid using ProBoards
Post by bellard on May 1, 2012 20:07:35 GMT -5
Errosion lovely.. I have to replace most of this no? Gears behind it are rusted a little but not chipping away
