Post by bellard on May 1, 2012 20:10:15 GMT -5
Btw I plan on not using the fairings at all only the lower headlight fairing. What I will be doing is build fairings with 28 gauge sheet metal. I'm very handy with sheetmetal and have every tool I need including a plasma cutter big grin:) I love this frame its has great potential.
Sent from my Droid using ProBoards
Post by 90GTVert on May 2, 2012 7:54:50 GMT -5
See if you have 12V at the positive post of the starter when you hit the button. If you do then it might be a bad starter. If you don't, back to checking wires. If you're used to scoots this will sound elementary, but just in case, you do need to hold the brakes to electric start most scooters. There's a diagram of the starting system in that link I posted earlier that shows how it's all tied together. If they ign switch isn't hooked up yet or bypassed, I wouldn't worry about it.
Post by bellard on May 2, 2012 8:09:25 GMT -5
Lol dang that is elementary jeez. Its funny when the Scooter is bare and you have alot of ideas running through your head u forget alot lol. I ordered everything I need. Ill have to buy a new cvt cover I think I'm going to get this one since the one I have is crap. Btw anyone know where to buy the two rubber prices that goes on both the sides of the Carb? I don't need the metal Peice for the intake manifold just the rubber Peice there and on the filter box. I'm assuming u can just replace the rubber Peice instead of the whole unit. I also need a 27mm flywheel puller .. I've already got the puller for gy6 why can't one tool do them all? Grr anyways if u know where to order the puller and Carb hoses u clamp on to it I'd appreciate it I've looked..
Post by Fox on May 2, 2012 13:15:45 GMT -5
Post by bellard on May 3, 2012 7:42:19 GMT -5
I got the scoot to run today after I started it. It was literally running in full throttle there's no throttle attached? What's the idle sequence on these puppies?
