Post by ryno591 on May 3, 2012 17:41:17 GMT -5
Hey guys! I've been looking around for some better front forks but can't find any. I have a 09 sunny 50cc 4t. Any ideas?
Post by Deleted on May 3, 2012 18:46:54 GMT -5
I have never seen any for a 4t specifically
Post by ryno591 on May 3, 2012 18:53:51 GMT -5
Ok, so I said its a 4t, that means its a 4stroke right?? LoL. Sorry I'm new to the scooter lingo.
Post by Deleted on May 3, 2012 18:55:14 GMT -5
Ok, so I said its a 4t, that means its a 4stroke right?? LoL. Sorry I'm new to the scooter lingo. yes 4t=4 stroke
Post by reveeen on May 4, 2012 2:25:17 GMT -5
I would *think* some stiffening up of some of the wobbly Chinese chassis might be in order before you run out of forking?
Post by skuttadawg on May 4, 2012 2:42:33 GMT -5
Look for some NCY forks
Post by ryno591 on May 4, 2012 13:07:18 GMT -5
I found some online last night but it looked like they were all for 150s
Post by ryno591 on May 4, 2012 13:09:15 GMT -5
I would *think* some stiffening up of some of the wobbly Chinese chassis might be in order before you run out of forking? . I think its called travel.....and your right the chassis on some of these things are very poor.
Post by Deleted on May 4, 2012 18:39:51 GMT -5
I found some online last night but it looked like they were all for 150s What i should have said is: 'I have never seen any specifically for a 50cc 4t'. sure would be nice.
Post by skuttadawg on May 4, 2012 20:23:27 GMT -5
Better luck finding a good nitrogen rear shock(s) instead
Post by Deleted on May 10, 2012 16:10:57 GMT -5
Measure the diameter of the fork where it slides into the tree. Many of those 150 forks on Racing Planet will fit a 50cc tree. There was a TNG Milano 150 here today that had 10" wheels that were no wider than the 10" wheels on a 50. Seems possible to me to use 150 forks that would then allow you to use 150 brake calipers too. Edit: The ones I see listed on racing planet for 50s are 27mm diameter. The 150 ones are 30-33mm. Seems to me you could use the 30mm ones if you pry the clamps on the tree open some. This would open up much greater options in brake upgrades as well.. Many 150 brake calipers are on the right side though so you would have to simple flip your wheel around.....but you would have to get a speedometer drive gear for a 150 also to make your stock speedo work. There are adapters for the 150 forks to allow you to use a 4 piston caliper too Might not even have to flip the wheel around.
Post by Deleted on May 10, 2012 16:34:24 GMT -5
Post by ryno591 on May 10, 2012 20:36:16 GMT -5
Wow......thanks for all the info!!
Post by Deleted on May 10, 2012 20:52:37 GMT -5
NP the 33mm ones probably wont work in a 27mm tree but seems to me you could pry the clamps open and use the 30mm ones no problem.
Post by teddy554 on May 15, 2012 9:21:10 GMT -5
