Post by bellard on May 4, 2012 10:31:32 GMT -5
I have looked at the right up on removing the oil pump. But its missing in the directions what exactly your suppost to take out to deactivate it. Or I'm just dumb not sure which once my flywheel puller comes ill be working on this. Any help with this confusion would be very helpful to me thanks again guys. Your helping me out a ton with these two strokes that I love and know very little about.
Sent from my Droid using ProBoards
Post by 90GTVert on May 4, 2012 10:59:26 GMT -5
I took out everything in that how-to, that deactivates it. lol If all you wanna do is make it stop working you can just remove the gear from the crank that drive the pump. Other option I've seen is to loop the oil line by attaching the output to the input. I just like getting it all out of there. It's not that much work and it's cleaner.
Post by bellard on May 4, 2012 12:20:26 GMT -5
What's the gear look like? Plastic? White yellowish plastic?
Post by bellard on May 4, 2012 12:21:34 GMT -5
Oh and should I remount the pump after taking out the gear? Or should I leave it out to reduce weight Sent from my Droid using ProBoards
440va
Crazy? No this is normal...
Post by 440va on May 4, 2012 12:56:43 GMT -5
you can leave it out, not that much weight but what's the real point in leaving it in? My whole setup is out, and I'm taking a tip from one of the other members, converting my oil tank to a reserve fuel tank
Post by bellard on May 4, 2012 13:08:14 GMT -5
Yea I was totally thinking about doing the same thing my self... not a bad idea. Please let me know how you do it I'd love to copy ya how much does the oil thingy hold anyhow? Sent from my Droid using ProBoards
440va
Post by 440va on May 4, 2012 13:59:41 GMT -5
each scoot varies, I'm not sure how much mine will hole, I'm actually sealing off where the oil level sensor went as we speak. I'll let you know what all I did once I get it all installed. You know how it goes, theory is a great idea, actuality can be whole other beast lol
Post by bellard on May 4, 2012 14:14:31 GMT -5
No doubt we will have to scoot together sometime possibly meet up n downtown or Chesterfield a half way point hehe. I don't mind driving far asking as I can ditch my lady long enough lol
Post by bellard on May 4, 2012 14:15:22 GMT -5
Maybe reuse sensor as a secondary gas sensor or that wont work?
440va
Post by 440va on May 4, 2012 14:43:39 GMT -5
I'm not too concerned with knowing how much is in reserve, the way I see it, once I have to flip to that tank, I'd better be finding a station soon lol. I scoot all over, that could be the death of me since I tend to go without thinking in most cases. One day I know I'll do the walk of shame, and knowing my luck it will be a long one.
So you're going premix and doing away with the oil pump setup too?
Post by Fox on May 4, 2012 15:03:42 GMT -5
I took off the pump and removed the gear from the pump shaft and then reinstalled the pump to keep dirt and road grime out of there. There's stuff in there that I'd rather stay clean.
Post by bellard on May 4, 2012 17:16:01 GMT -5
Yes I'm in the progress of removing it now. I hate China put n screws in hard to reach places... you'll see why
Post by bellard on May 4, 2012 17:19:15 GMT -5
Hehe I didn't want to have to remove the engine from the frame f that.. I won't need it anymore anyway. Hell I don't need more parts laying around the workstation ..
Post by bellard on May 4, 2012 17:20:51 GMT -5
Anyone recycle aluminum? Sent from my Droid using ProBoards Attachments:
Post by bellard on May 4, 2012 17:21:34 GMT -5
