Post by bellard on May 5, 2012 16:31:32 GMT -5
I got the scoot started its got a mikuni Carb on it. When the black slide in the Carb drops below the slide (when I screw it out even with the bore of the slide drops down and revs high but its like the sweet idle spot is just below where the idle needle is. Should I upjet a jet? Considering I have to basically choke the Carb to nothing to get it to idle or rev high?
Sent from my Droid using ProBoards
