Post by 90GTVert on May 12, 2012 9:43:40 GMT -5
Here's a quick tip about the little locator dowels for the CVT cover / case. Some of them are loose and whenever I pull the cover off they fall off somewhere and then I'm wasting time looking for them. That's especially bad if you ever breakdown and have to do a repair on the side of the road (wish I didn't know that lol). This is a really easy way to avoid losing them Take the dowels out, if they haven't fell out already. Clean the dowel and the receivers in the case and CVT cover. Put some red thread locker into whichever you'd like the dowels to stay in. I prefer the CVT cover. Put the dowels in, clean off any excess, and let the thread locker cure before re-installing. You could use a different adhesive or epoxy. I went with this because I had it around, it's strong enough, and I should be able to remove the dowels if ever needed for any reason.
