Post by cenzo989 on May 13, 2012 13:57:17 GMT -5
ey guys, how are you all? perhaps you can help me out..... I have a 2004 Yamaha zuma 50cc over the past few months i have did some mods to it. lights.......rollers ...exhaust.....belt.....clutch.....but not the engine yet anyway back to my problem... up till about a year or so ago .......my electrical system don't work the brake light...my signal lights....my horn is very low..almost faint........ and my electric start dnt work the only thing that work fine is my headlights...
the only time the signals and brake work or come on is when im sitting at a red light and rev it or when i twist the throtttle the second i go back to idle...everthing stops working...blinking.. here are sum pics of my scooter...atached
any suggestion on the problems at hand would be greatly appreciated..
Post by Deleted on May 13, 2012 17:12:11 GMT -5
sounds like bad ground.
Post by 90GTVert on May 13, 2012 17:47:47 GMT -5
:welcome2:
Check your battery and connections and check your engine and frame grounds.
Post by cenzo989 on May 13, 2012 22:22:48 GMT -5
thanx guys.. \
ill check it out
much appreciated....
