jcoahran
89 zuma ii
Post by jcoahran on May 13, 2012 21:31:06 GMT -5
well i got my big bore kit in today, only to find i can't start it due to lack of spark, i've took off the body and tracked down the wires from the coil to check for any pinched/broken wires, ive replaces the coil and cdi, still no spark, my battery is fully charged. i've made sure everything is plugged up correctly and checked the magneto i was told that thats how it generates its fire, as the magneto spins it goes under a lip, i looked at the lip and its about a half inch above the magneto and that doesn't seem like i would create enough electricity to fire, maybe im wrong, and i was hoping you guys would have a couple ideas so i could get this little beast on the road. any help is greatly appreciated, thanks.
Post by Deleted on May 13, 2012 21:36:09 GMT -5
all your grounds good?
jcoahran
89 zuma ii
Post by jcoahran on May 13, 2012 21:37:53 GMT -5
im not exactly sure. the guy i got the scoot off of told me when bought it some wires were melted to the frame and had to fix them, i was alright with that no big deal, but i can't find the ground that goes to the frame. any idea where its supposed to be?
Post by Deleted on May 13, 2012 21:41:50 GMT -5
im not exactly sure. the guy i got the scoot off of told me when bought it some wires were melted to the frame and had to fix them, i was alright with that no big deal, but i can't find the ground that goes to the frame. any idea where its supposed to be? from one of the starter bolts to the frame somewhere....and from the neg. battery cable to the same place on the frame..and from one of the valve cover bolts to the neg battery. Just go to autozone and get wire, terminals and a crimper tool and make your own.
jcoahran
89 zuma ii
Post by jcoahran on May 13, 2012 22:36:15 GMT -5
went to the shed and checked, all the grounds are there and in good condition....hope im not looking at a new wiring harness ):
Post by Deleted on May 13, 2012 22:54:09 GMT -5
the pick up coil is the next thing to check.
Post by Deleted on May 13, 2012 22:55:39 GMT -5
the pick up coil is the next thing to check. i dont guess you have a multimeter do you?
jcoahran
89 zuma ii
Post by jcoahran on May 13, 2012 23:11:28 GMT -5
no i dont :/ whats the pickup coil? the black box the coil connects to? if so i changed that when i changed the coil
Post by Deleted on May 13, 2012 23:19:14 GMT -5
no its the 2 wire thing down there on the case that gets signal from the magnet on the flywheel. you need to test continuity on it with a meter to see if its open.
jcoahran
89 zuma ii
Post by jcoahran on May 13, 2012 23:24:38 GMT -5
how often do they go bad? i seen this scooter run about 2-3 weeks before i purchased it. but i when i took it apart it was all coroded, even the flywheel so i took a steel brush and a drill and cleaned it all up. would there be any other symptoms of a bad pickup coil? one i can find without a meter?
Post by Deleted on May 13, 2012 23:27:18 GMT -5
you need to test continuity on it with a meter to see if its open. or replace it and see what happens. those are your options at this point. you say grounds are good. you say new coil and cdi. that leaves pickup coil and stator. you need a meter to check them....or replace and hope for the best.
Post by Deleted on May 13, 2012 23:29:19 GMT -5
more likely a bad stator since it was in a corrosive environment but a bad pick up coil cannot be ruled out with no meter.
jcoahran
89 zuma ii
Post by jcoahran on May 13, 2012 23:31:48 GMT -5
alright wish me luck on finding a cheap stator or borrowing a meter! haha thanks alot for all your help bro
Post by Deleted on May 13, 2012 23:32:53 GMT -5
if you plan to do your own work there are 2 things you cannot live without. a compression gauge and a multimeter.
Post by Deleted on May 13, 2012 23:34:50 GMT -5
