jcoahran
89 zuma ii
Post by jcoahran on May 13, 2012 23:48:53 GMT -5
yeah i understand now that i cant keep skating by on the bare minimum. since my dad's scooter won't run right we're probably going to use his stator since his scooter is a twin to mine. until we get the parts to fix his and mine next month though. who knows. we'll see. ill definitely be getting a compression gauge and a multimeter though, any other must haves for scooters?
Post by Deleted on May 14, 2012 0:13:47 GMT -5
the tools i use most are my 1/4 drive socket set and my 2 cordless drills. one drill has a phillips head bit, the other has a 1/4 drive bit for sockets/extensions. with those you can zip one apart and back together and be done while the other guy is still fumbling around with a ratchet and screwdriver lol
i have an air compressor but i also have tools for the variator and clutch...those are a must have too. a test light too
Post by Deleted on May 14, 2012 0:15:06 GMT -5
just make sure the drill clutch is set low when going back in with screws or you will strip them right out.
