Post by dizzee16 on May 19, 2012 10:05:00 GMT -5
Hey everyone! I just wanted to get your guys' opinions on something.... What would you recommend in terms of an aftermarket Tachometer for my Genuine Roughhouse? Digital or analogue, whatever you've used and what your opinions are on those products... Hopefully I'm not the only one curious about this and we can all share some great information! Thanks everyone for your input! Have a great weekend!
inuyasha
Retired Master Chief USN
Post by inuyasha on May 19, 2012 10:42:21 GMT -5
Post by moore716 on May 19, 2012 10:55:00 GMT -5
i am using koso multi guage speedo fuel guage and tach. It works great and the install is pretty straight forward. The only issue I've encountered is that since I changed out my coil and cdi to aftermarket supposed performance ones it can be erratic at times. This is from the electronics imo not the unit.
Post by shakerdriver on May 19, 2012 16:13:56 GMT -5
I've got the koso analog tach with digital temp gauge on my drag scooter. Tach goes up to 16000 rpms and I like it very much.
Post by shakerdriver on May 19, 2012 16:18:47 GMT -5
I got mine from sip for $117 shipped.
Post by stepthrutuner on May 19, 2012 21:32:40 GMT -5
If you just want a tach these are inexpensive and the one I have has worked good for about a half year. The TTO line is not illuminated though if that's important to you. trailtech.net/tto_tach-hour.htmlThe same cannot be said for their TTO cylinder head temperature gage as I and many more have found them problematic. www.trailtech.net/tto_temperature.html
Post by 90GTVert on May 20, 2012 7:12:15 GMT -5
Post by dizzee16 on May 20, 2012 10:57:05 GMT -5
Cool! Thanks everybody! I had never seen the Trail Tech before and it's definitely priced to sell... I was just looking at the Works Connection meter that looks the same, and is the same price, but seemed to be more responsive in the video. That's one thing I like about the analog vs. digital display is the accuracy factor. Obviously the readout is a little nicer with the digital meters, but I now I can't make up my mind which one I'd prefer...
Post by shakerdriver on May 20, 2012 11:17:57 GMT -5
The trail tech digital tach also has a hour meter and shows Max rpms when you shutoff the motor.
Post by stepthrutuner on May 20, 2012 17:50:10 GMT -5
The trail tech digital tach also has a hour meter and shows Max rpms when you shutoff the motor. Good points, Jason.
Post by dirtymoosetaint on May 20, 2012 20:00:46 GMT -5
I want to get a digital for my tao lol
Post by 2strokd on May 21, 2012 10:06:19 GMT -5
Trail tech is the way to go bang for buck. Something about that old school analog Tach wrapping the needle around 11,000+ is pretty cool though
Post by larry001964 on May 21, 2012 11:07:06 GMT -5
Trail Tech don't have a fuel gauge. If it did id have one.
Post by peteyparado on May 21, 2012 15:51:54 GMT -5
trail tech!!! i've got the there tach an there temp gauge,works great an water proof.an over a year old.
Post by stepthrutuner on May 22, 2012 13:59:25 GMT -5
