Post by dirtymoosetaint on May 26, 2012 10:49:02 GMT -5
I have a 2011 Taotao ATM 50 with the "Sunny Style 2" body. I was wondering if its possible to switch that body out with say a type 1 body or just the front end. I just dont like the front end and the way it looks. I was wanting to swap out the front with something else.
Post by Deleted on May 26, 2012 20:43:18 GMT -5
you will need the front nose, lid and turn signals but yes it should bolt right up.
jcoahran
89 zuma ii
Post by jcoahran on May 26, 2012 21:24:47 GMT -5
while we're on the subject, can we switch out bodies to a completely different (better) body?
Post by Deleted on May 26, 2012 21:37:11 GMT -5
ive never seen body kits for sunny frames...other than stock.
jcoahran
89 zuma ii
Post by jcoahran on May 26, 2012 21:41:19 GMT -5
well i was thinking that i could probably use alot of brackets, and cover the stock bolt holes, and make my own where the frame bolt holes are?
Post by dirtymoosetaint on May 27, 2012 7:09:19 GMT -5
thats what i was kinda wanting to do but i can not find anything online about how to do this or even if its been done before...lol...
Post by ososlow on May 27, 2012 7:34:45 GMT -5
It would be alot easier if you had a scoot with the body style you wanted next to yours. So you could see wich mounting tabs you needed to add. But it is definately possible, im in the middle of trying to make body panels from two compleatly different scoots work on my sunny frame.
Post by dirtymoosetaint on May 27, 2012 11:30:33 GMT -5
i think is what im gonna do is use the stock parts but add fiberglass pieces or "fx" to it. luckily i have an extra broken front nose cowl that i can play with lol
Post by skuttadawg on May 27, 2012 23:29:08 GMT -5
www.scrappydogscooters.com/CHASSIS_PARTS.html has body panels . I think it should be able to be done providing you switch em all out as they are the same underneath . I like the Handsome Boy design myself like my Magnum has as parts are dirt cheap and looks good
