Post by gnarlyocmd on Jun 3, 2012 18:34:02 GMT -5
I just bought a Peace Sports scooter with 561 miles . This is my first scooter and I'm wanting to know some questions . Is it normal for my scooter to shake alot ? And what are some (cheap) ways to make your scooter go past 32-33 mph? Thanks!
Post by 90GTVert on Jun 3, 2012 19:11:31 GMT -5
:welcome2:
Any more details on the shake? Vibration is pretty normal for these scoots. If it's excessive it may be a problem.
As long as there's no rev or speed limiter, I usually suggest moving up to a big bore kit. It's not the cheapest mod, but it's the biggest power difference. You can try tuning your CVT with different rollers or sliders and you might see some improvement. Not a bad idea to verify that the carburetor is in tune as well.
Post by gnarlyocmd on Jun 3, 2012 19:34:23 GMT -5
Any more details on the shake? Vibration is pretty normal for these scoots. If it's excessive it may be a problem. As long as there's no rev or speed limiter, I usually suggest moving up to a big bore kit. It's not the cheapest mod, but it's the biggest power difference. You can try tuning your CVT with different rollers or sliders and you might see some improvement. Not a bad idea to verify that the carburetor is in tune as well. Actually it don't shake like how it was before.It's just a vibration now . And I heard a special air filter would make it a tad' faster , is that true?Thanks!
Post by Deleted on Jun 3, 2012 20:13:06 GMT -5
can you elaborate on this 'shake' 1st? could be dangerous...we would hate to give advice on making it go faster when its already about to possibly shake apart...yanno?
Post by boostedmax on Jun 4, 2012 3:43:16 GMT -5
First thing to look over would be making sure all of the fastners are tight especially the motor mounts, wheel bolts, shock bolts, and Handle bars.
Next make sure your rims and tires are straight
The problem with the chinese scooters is there is no real quality control and unless u put it together yourself you are trusting someone else's tightening
