Post by gnarlyocmd on Jun 5, 2012 10:39:34 GMT -5
I just bought my scooter yesterday and it's having some problems today , it don't idle anymore , the front brake thing is lose (not sure if it's supposed to be like that) , and it used to go somewhere around 33-35mph(goes 30 now).I'm uploading a video of it at the moment so hold on.
Post by Fox on Jun 5, 2012 14:07:01 GMT -5
That brake is missing a bolt it looks like. Take out the top bolt (12mm socket) and take it to a hardware store and get another one just like it. Same length. Same thread. Then you may need to spread the brake pads apart with a screwdriver so that brake will slip over the disc. and install both bolts TIGHT. It's very dangerous riding with the brake like that. If you can't find a bolt the same exact length let me know cause I'm sure I have one. The idle needs to be adjusted is all. If you remove the four bolts under the seat the entire seat and seat tub will lift out and then you can get at everything. Then follow this guide: www.scooterforumonline.com/index.php/topic,1603.msg7405.html#msg7405
Post by canemanscooten on Jun 5, 2012 17:31:30 GMT -5
my scooter is doing the same thing as far as the idle is concerned im going to try out this suggestion for the idle thanks fox
Post by larry001964 on Jun 5, 2012 19:17:56 GMT -5
When was the last time the valves were adjusted, when your scooter won't idle that's a sign the valves may need adjustment..
Post by canemanscooten on Jun 5, 2012 20:49:42 GMT -5
I just adjusted my idle and it runs like a champ... I will be doing a valve adjustment in the coming weeks though as a preventative maintenance... gnarlyocmd i would take the advice of these guys 100% they are great at what they do/say...
