Post by one1 on Jun 5, 2012 19:04:59 GMT -5
I have to find a replacement screw, mine isn't grabbing the spark plug anymore and stranded me today. Why do they make it unscrewable if you can't buy the part separate? Surely it has a name and can be found for sale somewhere. '
Post by 2strokd on Jun 5, 2012 19:11:27 GMT -5
Its call Broken.. Get a NGK. This one and no more trouble You dont have to unscrew the plug ends anymore either.
Post by Deleted on Jun 5, 2012 19:36:15 GMT -5
Post by 90GTVert on Jun 5, 2012 19:52:35 GMT -5
I use the same ones 2strokd showed. I don't think you'll find the inside only. Whole NGK boot is around $3-4.
Post by one1 on Jun 5, 2012 20:04:52 GMT -5
I use the same ones 2strokd showed. I don't think you'll find the inside only. Whole NGK boot is around $3-4. I don't mind the price I just want to fix it. Didn't see a need in replacing the whole module an all like someone has said in a thread I found in search.
Post by Fox on Jun 5, 2012 21:23:46 GMT -5
Post by 2strokd on Jun 5, 2012 21:53:38 GMT -5
Ive fixed those before yeeeaars ago. I put some glue on the threads and screwed it back in with a flathead screwdriver. It worked until it broke again shortly after. The little week wire that holds the boot on the plug wouldnt work anymore, so the boot would fall off the plug. The style boot listed has a snap on (like a cars), so you dont have to unscrew the tip off the plug. MUCH better design. OH, and it LASTS!!! Best of luck with it... I know this stuff can be tuff!
Post by jmkjr72 on Jun 5, 2012 22:36:19 GMT -5
didnt you have an issue with this before and didnt we recomend that you replace this before
Post by 2strokd on Jun 6, 2012 8:55:35 GMT -5
I think someone here did? They screwed it back in and called it fixed... Worth a shot i guess?..
I think the factory style was meant to last through the test drive? Thats about it lol.
Post by one1 on Jun 21, 2012 17:22:09 GMT -5
Post by ososlow on Jun 21, 2012 18:06:13 GMT -5
I dunno man, ngk is a pretty big name! Im sure its better quality then the china piece
Post by Fox on Jun 21, 2012 19:33:11 GMT -5
Chinese plug caps = last for a while
NGK (Japanese) plug caps = last for years
Chinese plug caps are NGK knock-offs
Post by one1 on Jun 22, 2012 0:58:06 GMT -5
Old cap - 9 years old original cap came on scooter in 2003 with 3,200 kilometers on it.
NGK - as stated, likely similar performance since the scoot probably won't be an 18 year old Chinese scooter rolling around in 2020 it'll be the last one I have to use hopefully.
I've never had any other cheap scooter so I can't comment on them, but my cheater seems to be a completely different scooter from everything out there as it has been nearly perfect and turns ten years old in 6 months. This scooter was never supposed to be imported and it doesn't seem to play by any of the other rules. A 50qt-16 that runs 50-55 mph on the gps bone stock, has only had a starter clutch in 9 years, has a yamaha 97 cc clone stuffed under it, and is still pretty much perfect in 2012.
jonnienumberfive
just found this 1970 2 cylinder 2 stroke yamaha in a barn,been there since 1980
Post by jonnienumberfive on Jun 22, 2012 5:41:39 GMT -5
NOW thats a GOOD scooter !!!!
