Post by 90GTVert on Feb 16, 2010 13:48:53 GMT -5
This information was regarding Minarelli/Jog style two-strokes, the 139QMB uses the same size and thread diameter. I'm not sure if they are exactly the same lengths and quantities though. This information was provided by drawkward.I went ahead and replaced the bolts with allen wrench headed bolts that seemed stronger. I like the look a lot better as well. Looks more professional. Replacement bolt information for CVT cover Small bolts (x8) - M6 x 25mm with a 1.00 pitch Large bolts (x2) - M6 x 35mm with a 1.00 pitch
Post by 90GTVert on Jan 29, 2011 19:31:20 GMT -5
I needed a new set of CVT cover bolts for a Minarelli, so I thought I'd post what I used. The lengths I chose are slightly different than Josh's post above. 1 x M6 x 1.0 thread pitch x 60mm 2 x M6 x 1.0 thread pitch x 30mm 8 x M6 x 1.0 thread pitch x 20mm Chrome bolts set me back around $10. Standard bolts would be significantly less.
