Post by Deleted on Jun 7, 2012 12:04:09 GMT -5
under the fan shrouds on the lower right of the case there is a brass plug that is directly in the oil galley from the pump. I am thinking this would be the place to drill and tap for an oil pressure and/or temp sender. the drawback is its inside the fan shroud and if the sending unit used was too big it would block airflow to the cylinder possibly creating a hot spot. thoughts?
Post by ososlow on Jun 7, 2012 14:53:32 GMT -5
