belt
Jun 7, 2012 14:55:19 GMT -5
Post by teddy554 on Jun 7, 2012 14:55:19 GMT -5
I ordered this belt and the description just says-http://www.mrscooterstore.com/SPD/nk900-04--80004BCD-1326496909.jsp - Minarelli long jog yamaha version overdrive but the belt seems about a inch short it has no measurements on it and still have not figured out what v/s means maybe very short :lol: but it wont travel all the way up the back clutch there is about a inch left on the back ramps, does anyone have any input on this belts. I have put my old one back on because the new one has no take off i have to pedal to take off, plus it wont let the motor rev any before it catch i believe that is what is hurting my take off
belt
Jun 7, 2012 15:54:25 GMT -5
Post by 90GTVert on Jun 7, 2012 15:54:25 GMT -5
I don't know anything about the belt, but it sounds too wide. If you have a spacer, try spacing the variator halves apart farther so the belt can ride more toward the center.
belt
Jun 7, 2012 16:46:34 GMT -5
Post by reveeen on Jun 7, 2012 16:46:34 GMT -5
I ordered this belt and the description just says-http://www.mrscooterstore.com/SPD/nk900-04--80004BCD-1326496909.jsp drive belt Naraku V/S - Minarelli long jog yamaha version overdrive quad atv belt AEON ATV, COBRA ATV, MINI QUAD, Item Nr.: NK900.04 EAN/UPC: 4250362411204
but the belt seems about a inch short it has no measurements on it and still have not figured out what v/s means maybe very short but it wont travel all the way up the back clutch there is about a inch left on the back ramps, does anyone have any input on this belts. I have put my old one back on because the new one has no take off i have to pedal to take off, plus it wont let the motor rev any before it catch i believe that is what is hurting my take off The "better" question is: why? I see absolutely no reason to order a belt described in such a way.
belt
Jun 7, 2012 20:18:21 GMT -5
Post by teddy554 on Jun 7, 2012 20:18:21 GMT -5
it did say minarelli long and thats what i have, took a chance for 17.9 :doh: 5 with the item and the mrscooterstore are always cheaper then any were else. i did try spacers and grinding the outer plat like in the how to section, help but not much had to put old belt on.
belt
Jun 8, 2012 8:21:57 GMT -5
Post by 2strokd on Jun 8, 2012 8:21:57 GMT -5
On stock or non overrange CVT,s in CPI style Minarelli,s i would suggest a Bando 780-788 . I havent had the pleasure of trying a bunch of overpriced belts but i can tell you these work and they last. And FIT well
belt
Jun 8, 2012 9:08:09 GMT -5
Post by teddy554 on Jun 8, 2012 9:08:09 GMT -5
thanks, yeah i will do that
