jonnienumberfive
just found this 1970 2 cylinder 2 stroke yamaha in a barn,been there since 1980
Post by jonnienumberfive on Jun 10, 2012 19:40:21 GMT -5
I have read many times,rollers or sliders determine the "constant engine speed"..this being said I also hear lighter = more rpm BUT you loose top speed...this I can't understand,as rpm will determine top speed..all else being left alone..I'm hoping someone here can enlighten me...
katastroff
Dont F*%$ With Me, I'm a Dad!!!
Post by katastroff on Jun 10, 2012 20:02:52 GMT -5
jonnienumberfive
Post by jonnienumberfive on Jun 10, 2012 20:27:36 GMT -5
thanks,but not quite enough technical info....anyone else??
Post by 90GTVert on Jun 10, 2012 20:34:43 GMT -5
The problem with light rollers and losing speed is that speed requires not only RPM, but power. You can slip the engine to a high RPM through use of various components, but that doesn't mean it's making power there. For best results, you really need to keep the engine where it makes good power.
jonnienumberfive
Post by jonnienumberfive on Jun 10, 2012 21:20:14 GMT -5
thanks..so what the rollers are doing is keeping the engine in the "power band"..depending on what if any mods the rollers try to maintain the correct rpm ...
Post by 90GTVert on Jun 10, 2012 22:15:34 GMT -5
Right. The more you can stay within the powerband, the quicker and faster you'll be. That's why some aftermarket variators and torque drivers can really make a difference in performance. They are designed in ways that keep RPM more steady than the stock stuff so you can tune to stay much closer to peak output more.
