Post by one1 on Jun 14, 2012 13:10:47 GMT -5
Post by giantsaam on Jun 14, 2012 15:53:00 GMT -5
I use the silkolene and the pro RSF to rebuild race suspension and it is the only one I use. I have not used the 2 stroke oil, but I would imagine with the quality of their other oils that it is top quality.
Post by aeroxbud on Jun 14, 2012 17:43:54 GMT -5
Used their two and four stroke oil not bad stuff
Post by 90GTVert on Jun 14, 2012 20:33:09 GMT -5
Heard a lot of good reviews over the years (Silkolene). No personal experience.
Post by racerbugg on Jun 14, 2012 22:55:32 GMT -5
used their 2 stroke oil in my 125 race bikes years back and worked fine, remembered the exhaust smelled like cherries when mixed with avgas
Post by one1 on Jun 15, 2012 12:13:54 GMT -5
Think the one on the far right, the Scoot 2T, is what I'd use of the 4 for premixing?
Post by 90GTVert on Jun 15, 2012 15:13:17 GMT -5
The AGIP Speed or the Silk Scoot 2 I'd say.
Post by one1 on Jun 15, 2012 15:33:44 GMT -5
I seem drawn to the AGIP synth for some reason, but have no real reason. I went 2500 on the oil pump and the last 500 on premix so it's time to start thinking about synth mixes and longevity.
Post by 90GTVert on Jun 15, 2012 15:44:21 GMT -5
The AGIP is a full synth, Silk is semi. Info on both :
AGIP
"Full Synthetic lubricant specially formulated for 2-stroke street motorcycle engines, air and water cooled. For Injector or Premix formula.
The super-synthetic lubricating formula allows maximum performance in the most extreme riding and racing conditions. Contains extraordinary film strength additives, prevents piston seizing. Keeps power valves and exhaust ports absolutely clean. Drastically improves piston and ring life. Very stable at high temperatures.
AGIP Oil, AGIP Lubricants, and AGIP Coolants are recommended for all Aprilia, Moto Guzzi, Vespa, Piaggio products."
Scoot2
"Semi-synthetic 2-stroke engine oil, with MC-Syn Technology, for scooters and mopeds. Formulated with a clean burning blend that combats pre-ignition, ring sticking and spark plug fouling. Contains a low ash additive system and exclusive anti-wear synthetic chemistry to ensure long engine life with freedom from plug fouling and heavy combustion chamber deposits scooters, mopeds and mini-bikes. Designed for small capacity engines and is suitable for use with auto-lube injector systems or as a premix."
Post by lshigham on Jun 15, 2012 16:15:21 GMT -5
I'd not use their scoot2 but their Comp2 Plus Ester based, brilliant oil if a little pricey.
Post by lshigham on Jun 15, 2012 16:16:06 GMT -5
The Redline stuff is good two, my favourite in fact until the supplier in the UK discontinued it.
inuyasha
Retired Master Chief USN
Post by inuyasha on Jun 15, 2012 16:17:50 GMT -5
Hi looks like a very good product www.silkolene.com/If you do try it do post your results and views of the product Take care and ride safely dear friend Yours Hank
Post by lshigham on Jun 15, 2012 16:33:02 GMT -5
Course it's good - it's made in Germany and the UK. Not that I'm biased or anything :laugh:
To be honest, any half decent semi synthetic oil is fine in a 2T, even tuned ones.
