Post by seaquell on Jun 16, 2012 11:29:29 GMT -5
Just in case anyone puts on this kit the 24mm carb comes with a 1o2 main jet way to big even for my 52mm bbk and pod filter. the only place I could find 95-100 jets was jets r us, scrappydog doesn't even sell smaller jets. to make it work :dunno: this 24 carb takes bigger thread jets than a standard 18 or 19mm carb. I took a hint from90GTvert and heated up my 102 jet with a torch and with a torch tip cleaner the same dia. as a 95 or 100 stuck through the jet I soldered it shut a little for a quick fix. It runs so good now that I don't want to even put in a real jet.I have a real 95-98-and a 100 from jetsRus. I got 42.5 max MPH on my GPS so far, on level ground with minimal wind :rockon:
Post by 90GTVert on Jun 16, 2012 11:38:08 GMT -5
Thanks for sharing your experience. I think that tip was from stepthrutuner or 2strokd and I passed it along.
Post by growingrass on Jul 12, 2012 10:47:30 GMT -5
you have a 52mm piston and you only go 42.5? My scooter says its a 50cc but im not sure if it truly is because i can go 45mph on flat land no problem.
hit88
Post by hit88 on Jul 12, 2012 10:52:51 GMT -5
want's he works out the bugs and gets it broke in he WILL go faster. plus we dont know the weight diff between you and him. wind it up and gooooooo...thanks..
