Post by seaquell on Jun 18, 2012 21:28:02 GMT -5
I am having a tuff time finding a tuning set of clutch springs, like in a set of 3 each with 1000rpm 1,500rpm and 2,000rpm I have found a few for 150ccgy6 and some for 50cc 2t. They are mostly from china so I don't want to wait a couple weeks, only to find out they don't quite work on my 50cc 4T :banghead: I was just hoping someone has had both scoots or they know what fits. If nothing else works I can just order each separate.
Post by 90GTVert on Jun 21, 2012 14:28:49 GMT -5
Not sure about the 150. Here's a GY6 50/Dio spring on the left and a Minarelli/Jog on the right. I wouldn't go that route.
440va
Crazy? No this is normal...
Post by 440va on Jun 21, 2012 18:24:03 GMT -5
well if you go the route of buying each set individually, let me know which ones you don't use. I'll most likely buy them from you so you won't be out much.
