Post by toddskidmore1974 on Jun 23, 2012 19:55:01 GMT -5
hi everyone new to the forum here...... i have a 2005 beamer 2 has 250 miles on it but anyway i bought a technigas pipe, 90 jet in the carb,(stock was 80) installed a yellow clutch torque spring and a hipo variator from scrappydog scooters im a big dude 6'2 260 lbs. im hitting about 43 44 mph on the top end with great take off power does this sound about right with the mods done? stock it did about 32 with me on it. thanks
jonnienumberfive
just found this 1970 2 cylinder 2 stroke yamaha in a barn,been there since 1980
Post by jonnienumberfive on Jun 23, 2012 21:49:07 GMT -5
Hi, and welcome to the forum..I would say thats good...I'm about 240 and 6/2 and on my 50 cc hurricane with a technigas pipe and an 80 jet..4 gram rollers i could get 41 flat no wind...so i'd say your there..you may want to read the plug..it sounds like a lot of jet..but all engines are different.....
Post by 90GTVert on Jun 24, 2012 13:43:11 GMT -5
:welcome2:
Sounds about right. 32 seems slow stock unless something was restricted, but current speed is pretty good. Like J#5 said, you might find some more speed out of it by fine tuning the carb and trans if you haven't already.
Post by toddskidmore1974 on Jun 24, 2012 20:19:51 GMT -5
just a little update i installed the sliding weights that came with the variator and took out the rollers that came with the technigas pipe the sliders are a tad bit heavier so i achieved a solid 45 today with out sacrificing too much low end more than happy with the beamers performance,after all not too easy to hit 45 with a large guy riding thanks for the advice everyone
Post by skuttadawg on Jun 24, 2012 22:05:00 GMT -5
Its still tight and it will go faster after 1,000 miles or more depending on break in method . You should only use premium gas and 2T oil . I used Maxima and Bel Ray synthetic blend until 1,200 miles then switched to full synthetic . I am testing Motul 710 2T oil . A NGK iridium will fire the best and least likely to foul out from oil deposits . I hope you have a Gates Powerlink or other belt . I have an unlimited CDI but it made no diff since I have the stock exhaust on for now . Tried 4 gram rollers but were too light . Came with 6 gram but mixed them to equal 5 grams and it worked better for me .
What size is your carb ? I have a 19mm TK carb with 75 jet.
I have a 75cc BBK and saving up for a Leo Vinnce Hand made 70 and Dr Pulley variator and clutch along with a Mikuni oil pump . I can not wait to out run those on 150s not to mention cars from redlight to redlight . I push off with my feet in order to jack rabbit and get the hole shot . It isso much fun to out run cars ( even when they do not know we are racing LMAO ! ) and see how people go nuts when a moped is going faster then them and they go out of their way to pass me . I love too see the look on their face when I pass some going uphill as I can do 40 uphill with a running start , only registers 50 can bury it it . I broke the speedo cable the first night I rode it since I was on our " Redneck Autobahn " . I have huge 130/60/13 tires which do have some drag but the ride , handling and braking are worth some performance loss since it is much safer than those with 10 inch wheels .
Do you have a tach ? If so how many rpms can you hit ?
Post by toddskidmore1974 on Jun 25, 2012 19:12:20 GMT -5
i have the iridium plug, i run premium gas in also the gentleman i bought it from said he runs amsoil 2 stroke full synthetic in his other sccots too(oil tank is still full for now)i didn't pay much attention to the cvt belt but i thinks its a powerlink,awesome scooter one of the quickest stock(when i first got it) scooters i've ridden,and i agree on the leaving cars behind on takeoff and especially when they see a rather large fellow on it and waiting for it to take off real slow
