Post by Kristijan on Jun 25, 2012 9:38:58 GMT -5
hi..i have znen 50cc scooter..i have 17000 km..my belt broked 2 weeks ago..i changed the belt and i puted new MALOSSI variator with 5.1grams rollers (5 grams was the original)...and i puted new spring(MALOSSI that came with the variator pack) in the clutch..i drived like that 1 day..and the second day belt broked again..i bought another belt and two days drive again belt broked..what's the problem? some told me that i need to change the clutch..thanks to all..greating !
Post by usmcdoc on Jun 25, 2012 9:51:32 GMT -5
I believe they are right...that happens when the clutch goes bad..also if any tiny pieces of the old belt are still stuck in the clutch or variator...it will happen.Are you sure you have the correct belt size?
Post by Kristijan on Jun 25, 2012 9:53:24 GMT -5
thank you very much..mmm for the belt size i think it's correct 729mm 17.5..thanks again
Post by Fox on Jun 25, 2012 11:19:38 GMT -5
Go back to the stock spring.
Post by Kristijan on Jun 25, 2012 13:15:23 GMT -5
thanks..btw im going to buy new stock clutch..soo from malossi only stay the VARIATOR..is DYNAFLEX belt good?
