Post by 190mech on Sept 3, 2011 18:58:24 GMT -5
Man!T1 keeps you busy!! :jaw:
Post by 90GTVert on Sept 3, 2011 20:48:04 GMT -5
...to say the least. lol I don't think the very rigid pipe works well for a street scoot at least. Cruising at 1/4 throttle or so at 8-9000RPM going 45ishMPH my feet and hands were getting numb by the time I made the 11 miles to my friend's house today. It split the metal, not the welds, right on the seam where the stinger bracket meets the pipe. I might take it to a local welder because I damn near ruined the thing just trying to weld the belly extension in burning through everywhere. The thing is a monster with this pipe and I can't imagine it with anything else... well I can, but it sucks. lol One good thing anyway. I got the right adapter for the tach from DROWsports. Seems to read the same as the other sender, but I have only been easy on it so I haven't seen over 285 or so. I was gonna run it WOT for a moment on the way home, but things didn't go quite as planned as you saw. www.drowsports.com/product/71/Electrical/Gauges/Koso_Air_Cooled_Temperature_Sensor_Adaptor_
byte
Post by byte on Sept 6, 2011 12:01:39 GMT -5
Do you still have that slipping belt problem? Are you using your modded variator and pulley? Can you post pics of your assembled CVT. Just wanted to see the length of your belt when installed.
Post by 90GTVert on Sept 6, 2011 12:07:21 GMT -5
I don't have any belt slip issues now. I think it was actually a problem with the angles of the 2 halves of the vari causing a high rev spot that I thought was a slip. It's an unmodded Hoca vari now, modded fan, Bando 788 17 28 belt, 6g sliders, Hoca contra (stiffer than 2000), Hoca rear pulley/clutch assembly w/straight groove torque driver. Right now the belt is almost all the way to the center of the front pulley (2mm of spacers on the Hoca drive boss) and just shy of the edge of the rear pulley. I have been thinking for a while that the belt needs to be just a bit longer. I bought a 798 Gates and the stupid thing was shorter than my 788. :doh: I don't have a pic of it as it is ATM, but I can get one at some point if that description doesn't do it.
byte
Post by byte on Sept 6, 2011 12:21:20 GMT -5
That's good news. No need for the cvt pic then. I just hope that you'll not get those belt edges worn out again.
Post by 90GTVert on Sept 6, 2011 13:33:29 GMT -5
Last time around it didn't even seem to wear the belt down. It looked like it snapped the cords and the belt flew apart.
byte
Post by byte on Sept 6, 2011 17:09:52 GMT -5
This might help. 15 and 10 degree variator mod. Noticed anything?
Post by 90GTVert on Sept 6, 2011 18:34:16 GMT -5
Yeah. I dunno what mine are. When I mod the face I just do my best to file everything straight and even. lol
byte
Post by byte on Sept 6, 2011 19:01:42 GMT -5
These best done on lathe and must be done on both halves. I also did those filing before but it ended up a slightly bent crank until I met this guy who taught me about cvt angles and thickness.
Post by 90GTVert on Sept 6, 2011 19:19:33 GMT -5
I'd love to do them on a lathe, just don't have one or access to one.
Post by 90GTVert on Sept 9, 2011 14:22:59 GMT -5
I was cleaning stuff out and came across the instructions for the Koso tach. I think I wasted my money getting the proper AC adapter in hopes it would read higher than 302 degrees...
Post by 2strokd on Sept 9, 2011 15:50:50 GMT -5
I never noticed that on mine man....
Post by 190mech on Sept 11, 2011 18:24:35 GMT -5
Got a good start on it today; "Off with the old" "On with the new"
Post by 90GTVert on Sept 11, 2011 18:33:06 GMT -5
Looks great! It;ll be nice to get rid of that mess I call welding. lol Thanks so much John!
byte
Post by byte on Sept 12, 2011 8:32:05 GMT -5
glad to see that pipe regenerated :thumb: . love the revving sound of that. hope to see more vids of it revving. BTW what is the (rpm and exh duration) powerband that pipe was designed to?
