Post by johnnymac01 on Jun 28, 2012 22:27:09 GMT -5
G'day lads. Need to confirm my clutch and bell size before I get a performance pair. How do I measure these? Is the bell the inner or outer diameter? I know it's not much diff, but it could be a mil or so... Is the clutch size the same, as I've read in some places, or 2mm smaller, as I've also read? Thanks all. JM
Post by Fox on Jun 28, 2012 23:21:28 GMT -5
Post by reveeen on Jun 29, 2012 0:44:54 GMT -5
Post by 90GTVert on Jun 29, 2012 6:34:19 GMT -5
There are a few sizes, all measured in ID of the bell. Like reveeen said, if you get both the clutch and bell in the same size it's not gonna matter what you had. All of mine are 112mm, but I've swapped a 107mm clutch and bell on before.
Post by johnnymac01 on Jun 29, 2012 9:44:38 GMT -5
Sorry guys I shoulda been clearer. I'm not buying them as a pair. I'm buying them from Racing Planet Europe, and need to specify the size of each separately. So do I measure the clutch bell and order both in that size? Or the clutch 2mm smaller? Cheers Fox, but I have a Taiwanese Morini in a TGB. JM
Post by 90GTVert on Jun 29, 2012 10:27:21 GMT -5
Well when I ordered my 107mm setup, both were labeled 107mm. The ID of the clutch bell measured that, dunno what the clutch OD was but obviously less than that. All of my experience is with Minarellis, but I would assume the way they're measured would be pretty universal.
Post by johnnymac01 on Jun 29, 2012 21:20:51 GMT -5
Ah that's the spot. Sounds like they label clutches to match bell size. Awesome thanks bro. JM
