jcoahran
89 zuma ii
Post by jcoahran on Jul 8, 2012 20:51:48 GMT -5
title says it need this asap thanks
Post by 90GTVert on Jul 8, 2012 20:56:18 GMT -5
Excerpts from the BBK how to... Now remove the bolt, gasket, and spring in the cam chain tensioner. Some models may have a screw with a knob that looks like a flathead screw below it. For those models, just remove the screw. Next, remove the two bolts holding it and remove the cam chain tensioner. Next, reset the cam chain tensioner. If yours is like the one pictured, simply hold teh locking mechanism in and push the pin in as far as it goes. If your tensioner is the screw top model, turn the flat head screw while you push the pin in. Install the cam chain tensioner onto the cylinder with a new gasket. Insert the spring and install the bolt and gasket, or simply replace the screw on some models.
