Greg
Post by Greg on Jul 9, 2012 17:03:39 GMT -5
I'm working on a 2007 Redstreak Metro Retro scooter. The padding has come completely off of one of the front shoes. I can't seem to find these sized shoes anywhere. The shoes are 90mm (3.5") diameter from pad to pad and about 90mm from top to bottom (metal to metal). All shoes I am finding are the rear and larger 4.25" shoes. Has anybody bought these or know where to get them?
Post by skuttadawg on Jul 9, 2012 18:04:27 GMT -5
Is there a part number on them ? Post a picture of em ?
Post by Fox on Jul 9, 2012 19:08:22 GMT -5
Greg
Post by Greg on Jul 9, 2012 21:25:35 GMT -5
Shoes off, springs still in place. Just like they are pictured everywhere. They are small. Much smaller than the regular 4.25 rear brakes found in almost everything. I did see those at parts4chinesescoots but I was hesitant because there were no dimensions. I'll have to contact them and ask.
Post by Fox on Jul 10, 2012 1:07:41 GMT -5
I've dealt with them in the past and they were cool on the phone and the guy seemed very knowledgeable.
Good luck! I hope those are the ones.
Greg
Post by Greg on Jul 10, 2012 16:41:44 GMT -5
I've dealt with them in the past and they were cool on the phone and the guy seemed very knowledgeable. Good luck! I hope those are the ones. Thanks. I just talked to them. I hope they are the right shoes too. I'm crossing my fingers and ordering. He couldn't give me a diameter but said they are definitely smaller then the normal 4 stroke rear shoes. The only shoes smaller than the regular 4.25" that I know of are the fronts on this retro and the older qing qi and Geely front shoes which I believe are 3".
Post by craig on Jul 13, 2012 12:48:33 GMT -5
If You do not have a part number then the best thing to do is to take the hub and the brake shoe assembly to Your local clutch and brake shop to have the shoes re-bonded a good idea because they can check the hub for run out and skim the hub to perfect,then re-bond the shoes to fit ,I had a problem with a hub that was out of round causing the brakes to lock on a wet road dangerous when it's the front wheel.
Greg
Post by Greg on Jul 13, 2012 21:08:46 GMT -5
If You do not have a part number then the best thing to do is to take the hub and the brake shoe assembly to Your local clutch and brake shop to have the shoes re-bonded a good idea because they can check the hub for run out and skim the hub to perfect,then re-bond the shoes to fit ,I had a problem with a hub that was out of round causing the brakes to lock on a wet road dangerous when it's the front wheel. I might end up having to do that. I got the shoes from Partsforchinesescooters today. Wrong size. They are like 4.1" diameter. I had no idea front shoes would be this hard to get.
