Post by xxxSmokeKUSH420alldayxxx on Jul 30, 2012 12:35:12 GMT -5
Has anyone done this and have helpful tips??
Post by 90GTVert on Jul 30, 2012 13:47:58 GMT -5
Post by Deleted on Aug 1, 2012 1:16:03 GMT -5
If its a mainland china kit like off ebay or from SDS.....
1. make sure the oil ring gaps are not more than .020 or it will smoke like a train. 2. you MAY need more than one base gasket for proper piston/head/valve clearance. Check the distance between the top of the piston and the head gasket surface of the cylinder. should be....a few thousandths? not sure of the exact spec.
Post by xxxSmokeKUSH420alldayxxx on Aug 13, 2012 12:19:41 GMT -5
well i got it running great but it smokes like a train any ideas?
Post by abansb on Aug 13, 2012 15:37:50 GMT -5
I had the same problem it was the oil rings gap was to wide had to get another set of rings the 100cc kit I got off ebay with the yellow dot on the piston which 1FASTQMB mentioned above about the rings
Post by xxxSmokeKUSH420alldayxxx on Aug 13, 2012 21:20:54 GMT -5
Yeah i have a set of control rings coming. Did yours start off ok then gradually get worse?
Post by abansb on Aug 13, 2012 21:24:12 GMT -5
yea as soon as I started it smoked like crazy I didnt run it that much till I got the new rings in been about 5 months now and still doesn't smoke at all
Post by xxxSmokeKUSH420alldayxxx on Aug 13, 2012 21:39:36 GMT -5
Any tips for putting the rings on? procedure ect? Should i just replace the oil control rings or compression rings too?
Post by abansb on Aug 13, 2012 23:09:21 GMT -5
