Post by willis on Jul 31, 2012 1:55:32 GMT -5
I recently had my cdi die on me so while testing to diagnose the problem I swapped in a few spare parts to make sure what the issue was. Afterwards I replaced the cdi with an exact replacement but the cable on the ignition that goes to the spark plug boot was looking a little rough so i trimmed about and inch off. Now my ped runs but poorly a little sluggish on acceleration and will die when the throttle decelerates and when i try to keep up the rpms it just bogs ad if the timing is off. Could this be a symptom of the cable being shortened or is there a completely different issue.
09' gy6 50cc with 90cc kit ncy cdi and coil
Post by 90GTVert on Jul 31, 2012 13:12:34 GMT -5
:welcome: to the forum.
The length of the spark plug wire doesn't matter within reason (don't run it a mile). Could have bad connection there. Spark plug boot could be loose. Check that and all connections in the ignition system. Make sure you've got the coil grounded well.
Post by Goosey on Jul 31, 2012 13:31:27 GMT -5
Yea, I would check the boot is snug, even retrim a tad more and see if you can get a better connection to the wire/boot. Make sure your screw is centered to the wire part.
Post by willis on Aug 7, 2012 10:54:11 GMT -5
Thanks for all the info guys. I think I have found the problem. The cdi I i purchased from spec cycles appears to be for a 150cc not a 50cc so yeah bit of a head scratcher since they are completely identical other than the part number which is impossible to find.
