Post by xxxSmokeKUSH420alldayxxx on Aug 2, 2012 22:37:28 GMT -5
Post by xxxSmokeKUSH420alldayxxx on Aug 2, 2012 23:06:20 GMT -5
Or can i simply adjust the rockers somehow? Basically im reading that this is the 65 mm vs 69mm issue
Post by Deleted on Aug 3, 2012 5:10:11 GMT -5
it should work. your rocker assembly should be for 64mm valves and that head is 64mm. can you post detailed pictures of the issue?
Post by Deleted on Aug 3, 2012 5:14:53 GMT -5
riser things= rocker arms
