Post by eric1987 on Aug 5, 2012 14:26:20 GMT -5
So I just bought an Agility 50 scooter and it needs a CVT belt. Where would I go about getting one locally and are they hard to replace? I have mechanical experience working on cars somewhat. And where is a good place to get a helmet and what should I be looking to spend on each? Thank you!
inuyasha
Retired Master Chief USN
Post by inuyasha on Aug 5, 2012 14:34:54 GMT -5
Post by eric1987 on Aug 5, 2012 14:38:56 GMT -5
Thank you for the help! Now where can I get this CVT belt?
Post by 90GTVert on Aug 5, 2012 16:10:54 GMT -5
:welcome: to the forum. The only place to get a proper belt is if you have a scooter shop local. Otherwise, you'll prob need to order online. Unfortunately there's no nationwide chain of ScooterZone or Advance Scooter Parts or Scoot Boys.
Post by eric1987 on Aug 5, 2012 17:27:17 GMT -5
How long should I expect my scooter to last? Its got 2143 miles and its in pretty good shape. Its an 09.
inuyasha
Post by inuyasha on Aug 5, 2012 18:06:31 GMT -5
How long should I expect my scooter to last? Its got 2143 miles and its in pretty good shape. Its an 09. Hi With proper maintenance and repairs a very long time. ive seen some people hit 15,000+ miles on theres when cared for properly. Any scooter no matter the make or brand is only as good as the service it receives. Take care and ride safely Yours Hank
Post by eric1987 on Aug 6, 2012 21:12:16 GMT -5
I am having a hard time getting the CVT cover off of my scooter. I have the belt and removed all the bolts I could find along with the air filter box but it just wont budge! Its a 139QMB with 10" wheels.
noday
Post by noday on Aug 7, 2012 4:51:58 GMT -5
use a rubber mallet. a few bumps and it usually will slide off. most of the time the gasket is "sticky" and it is just a matter of breaking the seal
Post by eric1987 on Aug 7, 2012 14:51:46 GMT -5
Besides the 8mm sockets is there any other tool I might need to get the actual belt off once I remove the cover?
Post by Fox on Aug 7, 2012 15:59:09 GMT -5
inuyasha
Post by inuyasha on Aug 7, 2012 16:00:53 GMT -5
Besides the 8mm sockets is there any other tool I might need to get the actual belt off once I remove the cover? Hi An impact wrench, makes removing the variator very easy. Take care and ride safely Yours Hank
Post by eric1987 on Aug 8, 2012 13:03:05 GMT -5
Can it be done without an impact wrench? Just with a 17mm socket and manpower?
inuyasha
Post by inuyasha on Aug 8, 2012 20:47:05 GMT -5
Post by scootertrashrk on Aug 8, 2012 20:52:06 GMT -5
An impact wrench is the quickest easiest way, as long as you have juice to power it. But I actually prefer a spanner wrench. AKA "GY6 50CC variator remover puller tool". I picked up a cheap one for $5 You pull the fan shround and fan on the opposite side, exposing the flywheel. Hold the the spanner on the fly wheel to keep the engine from turning. And use your man power.
inuyasha
Post by inuyasha on Aug 8, 2012 21:07:28 GMT -5
