Post by scootertrashrk on Aug 7, 2012 20:22:07 GMT -5
Greetings,
Last week, I rode it 1 mile. Parked, restarted, went home, sat for an hour, came back out no spark.
I have no spark. The spark plug is fine, tested it on a friends bike. I replaced the CDI and the Stator/Magneto. Checked the CDI to coil wires - OK. I get 0.5 omhs (0.1 - 1.0 is standard) on the coil. The shut off switch tests ok also. I checked a few other wires that seemed to be properly connected.
So, I have a 10 year old "Taylor Pro Wire 8mm" spark plug wire. I get 6800 omhs on about 14 inchs of wire. It sounds a little too much to me. I am super broke other wise I would just go buy one.
Any one have more suggestions?
Thanks!
Post by Deleted on Aug 7, 2012 23:32:45 GMT -5
check kill switch position and function again. you are on the right track but something simple is being overlooked
Post by reveeen on Aug 8, 2012 9:41:37 GMT -5
Standard high tension "resistor wire" is 1000 ohms per foot.
Post by scootertrashrk on Aug 14, 2012 1:59:15 GMT -5
UPDATE:::
So, after checking in with NAPA and Advance Auto Parts. They do not sell individual spark plug :spark: wires. Luckily, I stopped at a car repair shop where they gave me one for free! It read 2300 ohms at 18 inches.
I was hoping this would solve my problem. It did not. I am going to check the wires connecting the ignition tomorrow.
Rule of Thumb: Trade a suspected bad part for a known good part.
Post by 90GTVert on Aug 14, 2012 15:37:32 GMT -5
Check the gap between the reluctor (raised bit on the flywheel) and pickup.
Post by scootertrashrk on Aug 14, 2012 20:40:02 GMT -5
I did do a feeler gauge test. I don't remember the size exactly but it checked out.
Post by Goosey on Aug 21, 2012 16:32:24 GMT -5
Is the engine turning over? If not, it just reminded me of my relay fail last year. Was working, starting, parked, 2 hours later not working. Fairly common thing I guess.
