Post by torinrage on Aug 15, 2012 21:44:21 GMT -5
One you probably bought the ebay kit so 99.5% sure your oil rings are crap and causing blow by which makes smoke.
Two the metal is common since you just rebuilt the motor. that is why when you buy a new scooter you change the oil at 300 miles and you'll find metal happens in most if not all motors once you do a rebuild on head or bottom end wether it is 1 cylinder or 12
also you probably have a gap in between your head and jug due to the missing head bolt.
that loud banging is probably you piston kissing the head when it comes up ever so slightly which is a very common problem with the 100cc kit hence why you need to install the non metal gasket on the bottom of your jug to give it clearance.
Post by Deleted on Aug 19, 2012 10:41:24 GMT -5
Does anyone have an idea why is smokes so much? Always check the oil ring gaps when using a china kit. 1 in 10 chinese '100cc' 82cc 50mm kits will have oil rings with the gaps too wide and will smoke like a train. Always check the piston/head clearance. 1 in 10 chinese '100cc' 82cc 50mm kits will require an additional base gasket for piston/head clearance. Sounds like yours needed an additional base gasket when built. it now has a cracked piston. Replace piston and rings. Inspect the bore carefully you may need an entire top end now.
Post by nitroman666 on Aug 31, 2012 9:31:28 GMT -5
I'm pretty sure this guy is just trolling everyone.
\\-olf
Iowa
Post by \\-olf on Sept 1, 2012 10:46:40 GMT -5
I'm pretty sure this guy is just trolling everyone. No doubt, cause no one is going to put in a BB kit, have a problem and then go "oh well, I'll run it till it blows up" but I like how the thread draws attention to the very real issues with these kits and what CAN happen, and underscores why I dislike these kits- because these kinds of issues DO happen.
Post by Air'd out Ruck on Oct 29, 2012 11:28:09 GMT -5
Ok update.....the cir clips failed and wore a groove in the cylender it blew up right after I sold it (the whole rebuild lasted maybe a month)
jerry
Scoot Junior
Post by jerry on Dec 7, 2012 21:08:11 GMT -5
I think from what I'm reading that I would take it down and start over, get new rings, piston clips, gasket, fix headbolt, get feeler guage and follow instructions!
jerry
Scoot Junior
Post by jerry on Dec 7, 2012 21:18:36 GMT -5
Well thanks guys, I just installed an E-Bay 100cc kit on my Chinese scooter. Haven't even started it yet. So maybe I should get some better rings?? a base gasket, I used better piston clips. So ,any other advice?? Jerry, Clearwater Fl.
Post by Deleted on Dec 14, 2012 19:45:04 GMT -5
Well thanks guys, I just installed an E-Bay 100cc kit on my Chinese scooter. Haven't even started it yet. So maybe I should get some better rings?? a base gasket, I used better piston clips. So ,any other advice?? Jerry, Clearwater Fl. you have probably cranked it by now but if not i would take the head off and put the piston at TDC see how much space you have between the top of the piston and cylinder deck, you may need a thick hoca base gasket or an additional stock one.
Post by Goosey on Dec 16, 2012 9:06:17 GMT -5
I do prefer Mr. Rucks avatar to his alter ego's.
