Post by thatoneguy on Mar 5, 2010 16:36:17 GMT -5
now i was doin a lil research on em cuz some one mentioned it and what kind of performance gains could i be benifiting from a 4 valve head??? and would i have to run racin fuel or some high octane stuff??
Post by ezscooterparts on Mar 3, 2011 10:24:47 GMT -5
you could probably use the current fuel for your scoot, but i would recommend 93 from local gas station, then do a reading on your spark plug.
Post by rocketdog on Mar 3, 2011 21:55:01 GMT -5
I have heard good reviews from a few knowledgeable folks on 4 valve heads. If you decide to purchase one, make sure you not only get the head but also the piston that matches it. Using that head with the stock 2 valve piston is almost worthless. If not destructive. You'd be better off with a ported 2 valve head in that scenario.
RD
