Post by cswilsn on Aug 24, 2012 23:19:25 GMT -5
Are there actually any cooling upgrades that might benefit someone who is in extremely warm climates? I'm wary to do anything to my cooling system, until I ask . I figure enough people here probably have asked this question. I've gotten mixed reviews by reading forums via google search, etc. I have seen where a lot of people have burned things up with fancy variator fans! any help or advice is greatly appreciated.
Post by 90GTVert on Aug 25, 2012 7:03:39 GMT -5
A cooling fan air scoop may make a slight difference. I found it to be worth a few degrees on my 2stroke. There are different fans out there, but I think for your engine they are all meant to reduce drag instead of increase cooling. Keep your carb jetted properly and that will cool the engine better. A larger carb will keep the engine a little cooler. You could try to install an oil cooler. Venting the CVT cover will keep the CVT cooler, and may help a small amount with the engine cooling.
Post by cswilsn on Aug 25, 2012 23:25:35 GMT -5
Thanks for the reply I think i'm going to leave it as is, and throw a temperature logger in both of the atm 50 a1's that we have. One has been modified, one has not. If I see it running any hotter, especially on the long rides I may look into this again .
Post by jmkjr72 on Aug 26, 2012 12:16:39 GMT -5
an oil cooler will halp big time if you already have an oil cooler a larger oil cooler
