Post by dirtymoosetaint on Sept 12, 2012 9:02:51 GMT -5
I just changed the oil and it smells kinda like gas...it smells like the rich smell I've been smelling when it starts...but it still won't start. I replace the sparkplug and a few hoses. I tested the petcock it works fine...any other ideas?
Post by Goosey on Sept 12, 2012 18:07:31 GMT -5
Did you do the valve adjustment? Are you getting spark?
Post by dirtymoosetaint on Sept 12, 2012 18:12:35 GMT -5
I havent checked the spark yet I was rushing before work I will do that tomorrow morning and I did do any valve adjustments yet either. It also doesnt help that I killed my battery trying to start it the last 3 days lol....but at this point thats the least of my problems...lol...
After reading a bunch on here I dont think its the petcock (but I havent totally ruled it out) I think its something in the carb. When I got the carb Kien Hi or somethign like that, I never jetted it or anything just "plug-n-play" lol...so im gonna take it of and go through it and see if there is an issue.
Post by teddy554 on Sept 12, 2012 18:27:42 GMT -5
the petcock is the easiest thing to rule out, they way that spark plug is burnt up i bet your valves are burnt also and not sealing right from running lean just guessing, you just need to stop fooling around and wasting your time and pull the head off and inspect the valves then the piston and cylinder, if everything looks okay put it together adjust your valves check for spark and try to fire it up then
Post by dirtymoosetaint on Sept 12, 2012 19:19:49 GMT -5
hmm..not the news i was looking for but makes sense...lol..i will do that in the morning thnx
Post by dirtymoosetaint on Sept 13, 2012 10:05:13 GMT -5
Post by teddy554 on Sept 13, 2012 11:46:32 GMT -5
From what i can see, the valves look fine and the piston but i am not the best judge of pics. Make sure you see no light come from the valves no crack, that they are seated tight.
Post by dirtymoosetaint on Sept 13, 2012 18:19:59 GMT -5
the only other thing I can think is that it has to be a carb issue....Ive noticed a few other threads in here with about the same problems only going 20-30 mph, not staying running, etc. The only thing i havent taken apart yet is the carb...lol Now when I got the carb it was off a scooter i bought for $50 bucks and I just put it on and went lol..so I bet the jetting was off or something. I will tear the carb apart tomorrow and post more pics...
Post by teddy554 on Sept 13, 2012 19:58:19 GMT -5
adjust your valves also
