Post by dirtymoosetaint on Sept 8, 2012 23:45:29 GMT -5
The reason I ask is cuz I've looked at everything to try to figure out why it won't start I think it's the petcock but I wanna make sure.
Post by Fox on Sept 8, 2012 23:57:10 GMT -5
To test the petcock: Remove the fuel line from the carb and remove the vacuum line from the intake and suck on the vacuum line like a straw. Fuel should run out of the fuel line when you are sucking and stop when you stop.
Post by dirtymoosetaint on Sept 9, 2012 9:40:28 GMT -5
Well the petcock is good..lol...i guess now it's to the carb lol...i did notice a small cut in intake manifold seal...
Post by reveeen on Sept 9, 2012 16:50:07 GMT -5
Check the rubber manifold beside the clamp..... they seem to crack there
