Post by msickora on Sept 19, 2012 12:22:01 GMT -5
i am not getting any spark i replaced everything it's all new and still no spark why?
Post by Goosey on Sept 19, 2012 14:13:48 GMT -5
What did you replace exactly. Causes of no spark can be, spark plug, coil, cdi, regulator, stator, relay, dead battery, dead fuse...loose wire, bad ground connection...there's probably more but that's off the top of my head.
Post by msickora on Sept 19, 2012 14:36:18 GMT -5
i had to rebuild the engine i needed to put in a new crankshaft when i put it back together i'm not getting spark now i replaced the cdi and the coil the stator should still be good because it was running when i took it apart the battery is new the plug is new
Post by usmcdoc on Sept 19, 2012 14:39:59 GMT -5
Post by felliott on Sept 19, 2012 17:10:55 GMT -5
Did you reverse the 2 wires coming off the stator ? I did it once and it drove me nuts untill I found it.
