Post by 90GTVert on Mar 13, 2010 22:57:21 GMT -5
Applying a die cut decal is a simple task, that some people seem to think is difficult to do properly. I put this how-to together to show you just how simple it really is. I'm applying the decal to a truck's window here, but the same techniques can be used when applying a decal to a scooter's body panels, windshield, or other surfaces.
The first step is to figure out where you want your decal. Choose a smooth, nonporous, surface. Hold the decal up to be sure it will fit there. Perhaps have a friend hold the decal while you stand back to get a better look.
Once you know where you want the decal, you need to clean the surface. Make sure the cleaner that you use is appropriate for the surface and leaves no residue. The surface must be completely dry before the decal is applied.
Put your sticker on a flat surface and use a squeegee or credit card to rub across the decal. This helps to ensure that the decal sticks to the proper lining.
Hold the decal up to the area where you wish to install it again. Look for lines you can use to help you apply the decal straight or on the angle that you desire. If you cannot find anything to use as a guide, you can apply a strip of masking tape to use as a guide. I am using the top of the window here.
Once you're certain of the placement and the mounting surface is clean and dry, separate the layers of your decal. Take your time and be sure that the decal sticks to the correct side, as shown here.
Use whatever you determined earlier as a reference point and begin installing the decal. There are a couple of methods for this. Which one you choose depends on the size of the decal and personal preference. Method one is to Hold tension on the decal, line it up, and then apply it all at once. This is most effective on small decals. Method two involves starting from one side and slowly working to the other side until it's on. Use a squeegee or credit card to help work the decal onto the surface.
Use a squeegee or credit card to work out any air bubbles that you see in the decal. Take your time here. Be careful not to get overly ambitious and rip the decal by applying too much force.
Once you are confident that all of the bubbles are worked out, you can peel off the application film. Start from one edge and use an angle as close to 180 degrees as possible to remove the film. Go very slowly and watch carefully so you can fix any issues that may arise.
All that's left now is to stand back and admire your new decal.
