tvnacman
Post by tvnacman on Nov 12, 2012 17:51:31 GMT -5
Hey guys , I was just wondering have any of you guys or gals used a 150cc manafold on a 50cc . Any special instructions tips or tricks ?
Thanks John
Post by 90GTVert on Nov 12, 2012 21:32:52 GMT -5
I used a 150 carb and intake and spacer on a big bored 50 (80cc). The install was simple, since they both have the same bolt pattern and the same throttle cable worked on both. I port matched the head to the spacer for the intake. I like the 50cc carb better though. I never could get the same throttle response from the 150 carb as I could from the stock carb. I think the lack of an accelerator pump may have been to blame more than anything else.
Post by reveeen on Nov 13, 2012 1:49:20 GMT -5
You may have to do a but of CAREFUL trimming of the cooling shroud to get the manifold on.
Worked ok here.
tvnacman
Post by tvnacman on Nov 13, 2012 6:59:57 GMT -5
Thank you guys. I'm on a learning curve here. Stepping into the parts sales with tech help. I don't have a 50cc to play with. The smallest engine I ever owned was a 70cc passport back in the late eighties.
Bernt I have been watching some of your videos, very nice job!
John
millsc
Post by millsc on Nov 13, 2012 14:41:26 GMT -5
i'm doing that mod now i have the carb waiting for my manifold to come in
millsc
Post by millsc on Nov 13, 2012 15:23:23 GMT -5
just checked my throttle cable was too short for the bigger carb i took my dremel to the brass part on the cable pushed it in further, cable fits
tvnacman
Post by tvnacman on Nov 13, 2012 17:47:39 GMT -5
Are you using the chrome intake or the rubber one?
John
millsc
Post by millsc on Nov 13, 2012 18:35:35 GMT -5
stock 150cc intake rubber one the chrome one is too big
Post by Goosey on Nov 14, 2012 9:10:13 GMT -5
The chrome one is too big for my 150cc also. Just doesn't fit in the space available.
zedooo
Post by zedooo on Nov 14, 2012 15:32:58 GMT -5
so what then...is the big carb better or not? how can it work without the accelerator pump? I want THE PUUUMP! i'm at 50mm piston right now...if I get the stroker crank I think the little carb will make no more sense :/
tvnacman
Post by tvnacman on Nov 15, 2012 18:46:59 GMT -5
Thanks for the input guys
