Post by lindhe on Mar 19, 2010 14:28:22 GMT -5
My scoot is leaking oil from the transmission area.... The guy I hired to fix it said the following:
1) I removed the clutch 2) Drained the remaining oil from the gearbox (very little see picture) 3) Removed the gear box housing. 4) Inspected the gears and seals 5) Reinstalled the gearbox cover with thread locking compound on the bolts. 6) Filled the gearbox with new oil
...now only a week later it's starting to leak oil from the same area again. What should I do? Replace the gearbox gasket and the gearbox bearing seals?
Post by 90GTVert on Mar 19, 2010 14:39:51 GMT -5
"from the transmission area" is kinda vague. Could be a drain bolt not sealing. Could have been over filled and it's leaking through the overflow passage. Could be a gasket not sealed. Could be a seal.
Post by lindhe on Mar 19, 2010 16:14:17 GMT -5
"from the transmission area" is kinda vague. Could be a drain bolt not sealing. Could have been over filled and it's leaking through the overflow passage. Could be a gasket not sealed. Could be a seal. Oh ok - So it sounds like I should just bring it back in to the mechanic and have him diagnose.... thanks!
Post by 90GTVert on Mar 19, 2010 22:52:45 GMT -5
Before you take it back, make sure it's not coming from a hole in the bottom of the case. There is a hole down there that is an overflow. If it came from there it most likley just means it was overfilled.
Post by lindhe on Mar 23, 2010 11:25:05 GMT -5
Good call, 90G - the oil leak has stopped by itself. I guess it was just overflow
Post by 90GTVert on Mar 23, 2010 13:49:42 GMT -5
;D Free is always good!
