Post by tygertung on Nov 17, 2012 20:23:30 GMT -5
What do you think about this idea? Wouldn't be hard to do, just get some high speed steel, grind it into an o-ring groove shape and machine a groove in the head. Wouldn't have to worry about sealing the head with head gaskets or anything. Could use a high temperature rubber o ring. I'm pretty sure this method is used on KTM dirt bikes.
Any thoughts? :scoot2:
Post by skuttadawg on Nov 17, 2012 20:54:27 GMT -5
Gaskets are cheap to buy and rubber would melt
Post by tygertung on Nov 17, 2012 22:20:10 GMT -5
I don't know if it would. The head only would be getting to perhaps 140 degrees c and oil seals for 4 stroke engines don't tend to melt and the oil can easily get that hot.
Post by lshigham on Nov 18, 2012 5:39:37 GMT -5
bare
Post by bare on Nov 24, 2012 22:10:59 GMT -5
Viton O rings Do Not "melt'. Someone is selling/inserting Chinee Crap rings :-) Gee.. that's never happened before? Oring seals require the cyl head be machined to fit a ring.
Post by jmkjr72 on Nov 24, 2012 22:51:50 GMT -5
liquid cooled kits run oring head gaskets
also there are many after market kits that run oring gaskets
