ela
Scoot Junior
Post by ela on Nov 19, 2012 5:02:47 GMT -5
I have noticed that my yamaha jog-r drops some oil/fuel. Yamaha has checked my bike and they don't find any problem they told me that all 2stroke after some time drops some fuel like that. Do you think there is no problem or the technician is wrong?
Post by 2strokd on Nov 19, 2012 9:23:07 GMT -5
Great Scooters!
Some is normal.. Enough to make the bottom of the airbox wet, but not enough to drip IMO. In your case its too much! It almost looks like the head, or cylinder could be leaking? It could also be the oil check valve, or one way valve that your oil line runs into. Going into the carb.. A sticking float in the carb will do this as well, but that look more like oil in your pics. Can you pull the fan shroud off and look at the mating surfaces? See if maybe the head is leaking, or the cylinder?
Blowin Smoke
Post by Blowin Smoke on Nov 19, 2012 18:36:42 GMT -5
Check the connection between the carb and the filter. Both of mine leaked in the same location. After the connection was cleaned and the clamp installed properly the problem went away.
ela
Scoot Junior
Post by ela on Nov 20, 2012 7:03:41 GMT -5
Found the problem, carb intake almost broken cheap to replace.
